The Mk1 wiper motor is easy to remove, take apart and refit. My motor wasn't working on intermit or slow wipe. the tray that the wiper motor sits in can build up with water, if this gets into the wiper motor it can cause rust to build up with can lead to:
Loud noises during operation
No movement of wipers
limited movement of wipers
jurks of the wipers when in use
Differnt speeds i.e slow = fast and fast = slow
and mabey some others, the ones listed above are from my exp.
the motor it self is held in place with a few bolts 13mm i think, the motor itself is held together by an alum key thingy (Dont know what its called soz) and is also held together by 3 clips that again are held inplace by this alum key thingy.
it might be worth taking it apart your self and trying to lube it, but i found that this was a waste of time for me. a replacement for £60 came from "EuroCarParts" (New) easy swap.
Btw, if your going to take the motor out i would recommend diconecting the washer tube, as this might get in your way when you take the cover off.
