Basically my problem is with the instrument cluster and I think it is a bad earth ... So the gauges goes at it's higher position, I remove the fuses f53 f37,when remove f53 that is from the battery and reconnect, the gauges returns to normal. But when I turn on the ignition the gauges goings crazy.Removing and reconnecting the f53 sometimes make some gauges to work fine. Now fuel and temp works fine but the speed and the other gauge is in the highest position but when I drive they goes up and down
So when i disconnected the battery and reconnected sometimes the cluster worked fine , I have cleaned the earth points in the battery and under. A friend of mine that repair clusters took a look at mine and find no issues. So I think it is a bad earth or something else
