General Injector rail petrol pipe removal
KRISPY1971
i dont know if anyone can help but i'm trying to replace the inlet manifold on a punto 1.2 on a Wreg and i can't seem to get the petrol pipe what goes to the injector rail off any help would be great thanks in advance
push them both in while pushing pipe in and relase both of them it will pop out
Thanks. I push the clips in and then pull 'the part the hose is fixed to' outwards by 2-3mm. If I then push that part back in it seems to be locked till i push on the clips again.
Presumably there is a rock hard o ring in there? I tried levering it off with two screw drivers on opposite sides once it comes out 2-3mm but so far i am reluctant to apply more force.
Can you confirm please that so far i am doing it correctly?
Edit: Can you describe in more detail please what you mean by pushing the pipe in? What part is going in and where? The part the hose is connected to does move in and out slightly and pulls out a bit with the tabs pressed.
circled in yellow
is this what you mean?
push plastic clips in and pull pipe out
