rceddie123
- Joined
- Mar 26, 2021
- Messages
- 6
- Points
- 1
Hope this helps someone! I have a 2.8jtd 244 based motorhome. Began getting intermittent issue with immobiliser light not going out and engine management giving u1600 (coded key not present) fault. After A lot of money and frustration I eventually Identified that if I move the key coil/ Ariel so it sat around the key it seemed to work ok. Bought a new Ariel/coil thinking it must be faulty (40 ohms resistance ) new coil (38 ohms ) fitted made no difference. 12v at immobiliser box seemed ok , wires not trapped etc. But output to key coil only 5v (is this correct?? Plugged in another immobiliser box and it also gave 5v). By moving key coil 5mm away from the key barrel it seems to now give enough induced current to make transponder work ok. This problem occurs with both keys..For now it is fixed/bodged but I would love to Know why / what has failed/ changed to make this necessary.
