Questa mappa non esiste su cinquecento o Punto. Esiste solo su Seicento sporting.Puoi pubblicare il tuo file xdf?
Non vedo quella mappa.
HyeI have always used this map to adjust fuel to proper AFR. It works with every temperature. Additional use correction map mentioned before. Everything you nedd you have in map definifion in tuner/tunerpro.
What`s wrong with you car now ?
Hi, have you solved it?Hye
I did tests with the emulator and the F73F map does not match the fuel injection timing at all.
Map is inactive at idle and on very low load.
Indeed if we look at the code, this card does not work below a temperature of 70°, nor below 37 kpa, or above 100Kpa, and remains inactive below 1750 rpm;
I did the test by changing the rpm value to 1000; and we see on the emulator that the ECU activates the map. I also changed the temperature threshold by setting a value to 100° and the ecu no longer activates the map at all whatever the rpm or load
If we look at the bin of a Punto 1.1 for example, all the values are 0 up to 1250 rpm and 102 Kpa.
what exactly do you want to do?Hi, have you solved it?
I'm not very expert and I have a huge mess in my head. I would like to understand which maps I need to modify to increase petrol injection. What does the "fuel main" map correspond to? Should it be changed?
You have ori to share?I have the same problem as you. The only difference is that I work on a five hundred 900. I have gaps below 3000rpm.
Yes ,I used IDA vs 6.8 32b; I found it on web.Pasto do you use ida to find maps? I would like to try using it. I downloaded the free version but it doesn't work, you need the pro version and the license costs a lot.
What is his name? Some links no longer work.You don’t need IDA, you could use the disasser posted in the first post of this thread. It worked fine for me
unfortunately the link no longer works and GECU is no longer availableYou don’t need IDA, you could use the disasser posted in the first post of this thread. It worked fine for me
here s simple xdf based on woj with map adress for your panda;OK thank you. Yes I can wait, in the meantime I will try to find IDA vs 6.8 32b to try to analyze the file.
Thanks, I found some maps using winols. I would like to try ida but I can't find one. Do you have a link to download it?ecco un semplice xdf basato su woj con l'adress mappa per il tuo panda;
ci sono molte altre mappe ma vi aiuterà a trovarle più tardi se lo desiderate; lì potete già lavorare sulle principali
here you areunfortunately the link no longer works and GECU is no longer available
Eccomi qui
