Is it possible that high oil consuption might result in problems starting when the engine is cold?
My Punto 75 SX is consuming a fair amount of oil but I've kept in within reasonable levels by mixing some additive into the oil. I, however, added almost 1½ litres of fresh oil into the engine last friday and the engine started to smoke a lot more and it has been difficult to start since that.
Is this a coincident or can there be a connection? I have to run the starter for a long time, the engine fires up, misfires and dies again. I start it up again, same procedure a couple of times until it stays on. I changed the coils, spark plug cables and lambda this summer.
