Technical Help! Radio wiring
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Gerolf VC
Hi
Can someone tell me what the wires of the original fiat bravi radio mean like color-purpose ;) i'm replacing it wirh the pioneer avh 290bt an don't know what the original wires mean.
Kind regards
Gerolf Van couter
Hello
thanks for the reply. i've seen that diagram but doesn't really match my wiring. i will post a photo later of the situation.
Hello
PLEASE HELP, post a diagram or somthing please I'm so lost I can't find out where the wires go
OK, i will try again, what is the problem you are facing?
It's been 3 moths and you have not found the diagram, but have you been trying?
Get the right wiring adapter for your head unit to ISO standard.
Then only real issues i can see you having are:
- the new stereo will not turn on -because you need to use a multimeter to find and move 1-2 wires, for the power(should be switched power..take it from the +12v cigarette lighter), and then a constant +12v for memory. You will need your new head unit's diagram to move those wires accordingly.
- the steering wheel controls will not work - because the controls work through the CAN network. And most head units do not support that, you need to find that out yourself. There are some CAN -to -whatever adapters that can make the controls work.. but i have no idea what/if any are going to work with your setup.
At this time i'm sure i did more research on the damn thing than you.
I'm guessing by "it's been 3 months" you mean the OP And not me ask only commented yesterday and I've already fitted it. I posted a tread about how to wire in a ignition switch live as my fiat bravo 2007 didn't have one so had to take it from the fuse box
