Regata 100S ie,, 1585 cc, 1986-89, Engine Code 149C3000
Ignition data
Regata 100S ie,
Ignition system type: El-ecu
Ignition coil make/type: Ma/BAE209BK
Supply voltage: n / a
Primary resistance: n / a Ohms
Secondary resistance: 3330-4070 Ohms
Distributor make/type: Ma/-
Contact breaker gap/air: n / a mm
Dwell angle: n / a Deg
Ignition Timing - unleaded: 10/850 Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 10/850 Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: O/S/F
Firing Order: 1-3-4-2
Spark plug make: Bosch
Spark plug type: WR7DC
Electrode gap: 0.7-0.8 mm
Fuel System
Regata 100S ie,
Fuel type: L/U [-88=98 Super]
Fuel pump type/pressure: Elec/1.0 0.15 bar
Engine idle speed: 850 50 rpm
Fast idle speed: n / a rpm
CO level at idle speed: 1.5 0.5 Vol %
Engine Data
Regata 100S ie,
Valve clearance - inlet: 0.41-0.49 c mm (cold)
Valve clearance - exhaust: 0.46-0.54 c mm (cold)
Compression pressure: n / a bar
Oil pressure: 3.4-4.9/- bar/eng/rpm
Radiator pressure cap: 0.98 bar/type
Drive belt 1 - size: 9.5x938 KDB938 mm/type
Drive belt 2 - size: n / a mm/type
Electrical System
Regata 100S ie,
Alternator output: 55/3500 Amps/eng/rpm
Regulated output: 14-14.3 Volts
Battery: 12/55 V/Ah
Starter motor make/type: MA/E95-1.1kW
Other data
Regata 100S ie,
Clutch operation type: Cable
Clutch adjustment: 15/Below B.Ped mm
Cambelt failure: Damage
Cambelt Part Number: 5956106
Tyre pressures: 2.2(31)f 2.2(31)r bar (psi)
