Technical heater erm arrggghh hot
dillinger39
Established member
manchester
the heater in the cinq is a little too good is this a problem. Its getting really really hot. coolant is ok, every thing is ok why is it so hot.
thats in the blue pal
thats the problem
i don't think its related its the eingine thats hot
its the engine in mean not the cooler in the car. It seems to get up to 90 really reall quickly
Ah, sorry. If you have heat coming into the car with the control in the blue, then the lever has become disconnected.
If the heat is only showing on the guage, then, as above, it may be fine, just make sure its not going any higher and that the fan operates to cool it down.
The heater is really a big problem. a little to the left is cold and a little to the right is 50 degrees celcius. :bang:
Turn it a little to hot and lower your window (y) :D
