Italian Job
Bloody hell where is that coming from
Do the same leave the relay out and the reversing light switch disconnected
This appears to be the case not definate but appears to be. I think when the engine is running the resistance is 0.7 and wobbling this would blow the fuse. You guessed it raining here just now forecast is better later.Just a thought all OK until you turn the engine on. What happens if you remove the fuse start the engine then with it running replace the fuse ????????'
Thanks for the input have taken resistor ,blower and connectors apart under glove box all appear soundfixed my mates blower last week, his blower was arcing at the connector under the glove box, does yours have a pollen filter, and is it blocked, this was the cause of my mates punto mk2's blower over heating and melting the connector, causing the short, sorry if this has been covered, but his is fine now...
