thetourist85
- Joined
- May 28, 2012
- Messages
- 1
- Points
- 1
Hi, hopefully someone can shed some insight into this issue.
I have a Grande Punto 1.3 MJ. When the air conditioning is on, the car will stall very easily when pulling away from idle.
Having done a little bit of research, it seems it may be something to do with the idle control valve? Is it likely to require replacement?
Does anyone know if this is something I would be able to investigate/fix myself (limited technical car knowledge)? If not, any idea what sort of cost to repair this might be?
Many thanks.
Many thanks.
