jolly500
Hi all.
Where do I find the engine timing marks on a Giardiniera?
Steve
Steve
Hi,Hi all.
Steve
Many thanks for that.The Giardi static timing mark is a tiny slanted foundry projection just under the distributor body, on the distributor tunnel on the timing cover.
Very difficult to sight using the timing light, as the distributor body is in the way...
Thank you again. will give it a go at lunchtime.I have no experience of the "normal" engine.
The static mark I described and the mark on the rotor align at TDC for either cylinder.
Absent a "quadrant" timing accessory, I have marked the rotor at 10 and 18° to the right of the TDC mark, and these align with the static mark
at idle and full advance respectively, under the strobe light.
Dead simple, I hope my description is as clear.
I tried it yesterday and it worked first time after 3 years of sitting in my driveway.I have no experience of the "normal" engine.
