I'll try and explain the problem......you'll kno wwhat I mean if its already happened to you.
The pin holding the arm of the damper device in the front door of my marea has snapped. As a result the arm has disappeared into the door and I cannot seem to pull it out again. I am unable to pull it out with pliars. Can anyone suggest the correct way of getting the arm out from within the door. There is enough of the arm for me to put a screw driver through it and pull alittle, but it just retracts into the door.
Fiat Marea 51 plate estate
