hi everyone just a quick question has anyone had any trouble fitting 4x100 17 inch alloys to fiat hubs using wobbly conversion bolts.for sum reason my passenger side front is scrubbing the inside tyre off and it has a wobble at 65 help:bang:
sounds to me like one of the rings is missing
Yup. When using wobbly bolts if the wheel bore is bigger than what the hub takes then the wheel won't be centered properly.
When you use standard bolts the bolts will centre the wheel on the hub but never ever just use the bolts to centre and hold a wheel. Always use a spigot ring.
Get suitable spigots and fit them and that should cure the problem
cheers forthat lads the car has had new gas shocks ftted and the alloys have the correct spigot rings.the wheels have been balanced and the trackin is fine still got a wobble at 60 ish only thing i can see is that an antirollbar bush is fuked that would not give a wobble would it/
