My new active sport has a boot key slot, but the ignition key doesent seem to shift when it is inserted, is this a key problem or is the actual boot lock broken.
If the key works in all the other locks it suggest its the boot lock at fault, could be a broken lock could be its been replaced at some point for a lock that uses a different key, the application of some common sense should help you solve the problem
But thats annoying when you just need to chuck sumet into the boot....
So you have to open the car - squeeze down the tiny gap cause the tit who's parked next to you thinks your a size 4 to pull the lever to prang his door cause that christmas turkey still hasn't shifted - only to get in the bloody boot?
Anyway
OP - pop the boot pannel off - get it inside warm it up - give it some lubrication and check nothing obvious is broken and see if you can get it working
