Got Remote locking?
Just one door lock?
Door locks like maintenance but almost never get any! Out of sight... out of mind
To rule out the previous suggestions easily..Yes got remote locking. The issue is affecting both rear passenger door locks
Pushing the handle shouldn't make any difference, unless the handle stickingThey only shut if you push the handle from the outside,
I think it is the handle sticking. The lock itself is fine, but for some reason, the handles stay up in the passenger doors so I have to flip them down for the doors to shut.Pushing the handle shouldn't make any difference, unless the handle sticking
At least 4 people have had the same problem here
Panda passanger door handle "sticking" / not releasing | FIAT Panda (Mk3)
I saw that there are some posts on this topic over the years but I chose to revive it anyway since I couldn't find my answer. The door handle on the front passanger side gets stuck when opened, and has to be pushed back down manually in order for the door to lock. This to me wouldn't have been...www.fiatforum.com
Personly wd40 wouldn't be my preferred solution its just wax desolved in a solvent. Often reoccurs once the solvent dries off.
I have had one fail several years ago. I can't remember what I used. I normally have isopropyl, meths, wd40 and engine,oil knocking around. I tend to thin engine oil with meths in all honesty I can't be 100%
Yep spray some solvent and dribble some thin oil and you should be good to goI think it is the handle sticking. The lock itself is fine, but for some reason, the handles stay up in the passenger doors so I have to flip them down for the doors to shut.
