i have a marea weekend estate which had a water leak coming through the headlining, i striped the interior and found that somebody had chopped the drivers side rubber drain tube which runs by the side of the screen in half and blocked the end of it which was causing the water to back up and leak through the roof lining, i thought i had sorted this by joining the tube but then found out that the other end of the tube was now hanging out behind the fuse box so leaking into the footwell . was just wondering does anyone know where the hole is to put the tube through so it drains the water out through the wing thanks
