Hello,
We changed the gearbox to a manual one and since then the rpm is stuck at 2000 rpm. At start it accelerates up to 4000 RPM then it decreases to 2000 RPM without removing your foot from the accelerator.
it displays a fault code 035F on diagnosis, it cannot be erased. I have already replaced the turbo actuator, turbo electronics, map sensor, turbo, check the wiring but the fault is still present. Has anyone ever had this problem ?
