The inside of the the TPMS valve on the OSF wheel is corroded and the valve core cannot be removed. I've had the valve replaced with a standard rubber one but obviously the tyre pressure warning light is now illuminated. I've been to the Fiat dealer and the valves are £35 + vat.
Does anyone know if these can be sourced elswhere for less? The part No. is 51839114. just for information someone had stolen the metal valve cap and water had ingressed into the valve core. The valve body is alloy but the valve core is steel, the inside was so badly corroded that the valve core snapped when it was removed. The learning point is that if you have TPMS valves fitted to you're car make sure you have caps fitted at all times. The car has only done 13,000miles.
