Hi
have a look in the forum downloads for the service manual
If you struggle I can look in my paperwork for yo
I looked at the 1999-2000 service manual and theres no relay/fuse box in the upper left side of my Bravo 1.6 2001 engine area.Hi
If you struggle I can look in my paperwork for you
The one on the top right contains a few fuses only. No relays.
There is a single red relay in this box. Could be the right one.@dribo
Tell us what you find
I made a new ground for the fuel pump into a different ground point. I couldnt track the ground easilly and taking off all the panels seemed like a pain.You mean the ground wire was bad or you pulled new ground for the fuel pump or fixed a bad connection?
Inertia switch is on the ground side so if you pulled a new wire it is now bypassed.
