Hi everyone, just wondering if anyone out there knows how to reset the diesel fuel pump on a 500, it has been in a collision.
I just found this on eLearn for the 1.3 MJet 500.
I've no idea if it will work, but at least it won't cost you anything to try. Please report back, either way - it would be useful to know if it works.
Here goes:
Fuel cut off function
There is no inertia switch on this vehicle; the fuel cut off function is managed in accordance with the logic described below:
1) the Air Bag control unit detects the impact and transmits the activation of the FPS (Fire Prevention System) via the CAN
2) after having received the FPS activation signal, the Body Computer Node:
- activates the hazard signal
- switches the courtesy light on
- unlocks the doors
- transmits that the impact has taken place via the CAN (B and C)
3) the instrument panel signals that the fuel cut off function has intervened
4) the engine management control unit interrupts the supply of fuel.
Rearming
The following procedure should be carried out using the steering column switch unit lever to restore the correct of the vehicle
KEY OFF (starting condition)
KEY ON
Activation of right indicator
Deactivation of right indicator
Activation of left indicator
Deactivation of left indicator
KEY OFF
