littlephil
right, took the car out for a run, when i hit about 5000rpm it started to cut out and misfire, pulled over and it cut out. started easy ticks over for a couple of seconds then cut out, everytime i pressed the accelerator it would start to missfire then it fires and revs. At this point it seems that to keep the car running you've got to work the throttle pedal. won't run properly under 3000 revs, runs fine at about 3500 revs but its hard to keep it there. i think it may be fuel starving, the inline filter is clean. is there a filter anywhere else? could it be the fuel pump? Once its been stopped for a while it will fun fine as long as you don't take the revs up too high. what can it be? :bang:
