Similar problem to what I had with my amp, doesn't turn on. Tried the solution I came up with where I connected the REM to the ignition barrel, no luck.
Strangely the amp works in my car with my wiring, so I know it's a wiring/HU issue. The amp should turn on without the RCA's attached, but it doesn't, it only powers on when the RCA's are plugged in. Could this mean that the HU is sending 12V down the RCA's? There is no output when the amp is on by the way, i.e. no signal from the HU.
Any suggestions? Hu need replacing?
Cheers,
Ant.
Cheers,
Ant.
