M martimcfly New member Joined Sep 20, 2009 Messages 10 Points 2 Location Scotland May 10, 2012 #1 Would it be easy or not to transplant a 1.2 16v or a 1.4 16v into my 8v mk 2
Azzam Patron member Parked in the garage Written a guide Joined Nov 21, 2009 Messages 849 Points 230 Location In a Pizza Box :) May 10, 2012 #2 you will need to change the ecu, fusebox, underbonnet fusebox, engine wiring loom, clocks probably more, your better off just buying a 16v punto and sell your 8v
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 May 10, 2012 #3 straight engine swaps aren't a problem Ie 1.2 8v for another 1.2 8v off a mk2 to mk2 But shoehorning others in can be abit iffy, as alot of mounting points wont align up As said - 16v's have bigger brakes and different suspension setup to handle the different power the 16v's give off Imagine telling your insurance about it? So any modifications Well yes Engine Engine electronics Brakes Suspension Gearbox etc defo cheaper to get a good 16v Ziggy
OP OP M martimcfly New member Joined Sep 20, 2009 Messages 10 Points 2 Location Scotland May 10, 2012 #4 OK message understood loud and clear. Im off to look for a cheap 16v, thanks for the advice..
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool May 10, 2012 #5 Being a Mk2 makes things harder cause of the dreaded Canbus stuff. It'd be much easier on a Cento or a Mk1.
S s and b Distinguished member Written 5 guides Joined Mar 13, 2011 Messages 7,620 Points 1,453 May 10, 2012 #6 martimcfly said: OK message understood loud and clear. Im off to look for a cheap 16v, thanks for the advice.. Click to expand... copart have a place in scotland have you considered a damaged car?
