Technical Engine Check Light with misfire error - Punto Grand (2006)
Banduka Jayasundara
Riihimaki
I have facing an issue that appear engine check light with misfire error. and it felt little slaggy and suddenly stop the engine when rpm goes to under 1500. What kind of fault this is? Plugs, coils, timing belt? Also there is little noise in alternator than usual.
Lack of basic, preventive maintenance piled up over years. There is no "mysteries" in those FIRE family engines, threads like that are pretty boring and lame (crank no start, stalling, misfire, check engine, power steering cutting off, water in the boot/trunk etc.).
Yes, it is a little bit of everything. Probably swapping one part will not fix this car now (now it's too late).
Timing belt, valve clearance (all 8V engines), VVT operation (1,4 8V) spoiled due to dirt in the lubrication system (plus there is a loss of pressure, because an "o-rings" under the camshaft cover can leak), camshaft lobes "polished" a bit. Next of course the ignition system (old coil pack for example), fuel system (old fuel pump, dirty injectors). PCV "breather" system (contains TWO hoses and orifices to be cleaned). Oldest Grandes have improper water drains, water pours on the alternator, shortening the life (and bad alternator can stall the engine). Clutch switch (ECU uses this "signal" to control the engine). And so on...
Now tell me, how many of those terms above "ring a bell"...
