Styling Eibach front camber adjustment bolt question...
The advert says its a camber corrector to make the camber less negative (pulling the bottom of the wheel in compared to the top) so on very low drops the axle doesn't look broken. Its a long bolt so probably enough.
so you CAN do negative camber with these? just spin the lobe on the bolt round 180 degrees should work? there's 2 bolts that hold the strut aswell so one of them should give more camber than the other.. will find out when i fit them
