hi all im new here i have an 82 fiat spider 2000 i was wondering if its possible to change from the fuel injection to weber type carbs ?
would i have to change the distributor is this at all possible ? just looking for some hints or tips or possibly a website with info on converting it ..as the efi is screwed it would cost me more to fix it than i paid for the car ... the car does run ..but alas i just want something i can work on and not have to take to a shop ..
the current problems it has with the bosch injection as far as i can tell are fuel pump,air flow meter,air hose has a huge hole in it,seals upper and lower ,and possibly more.. i got the car for 200.00 bucks it will run if i spray starting fluid in it.. but only for 30 seconds or so..but it cranks right up when i do and the motor sounds fine.. other than the fuel system problems and needing a really good cleaning if i could get it to stay running i could drive it till i can afford to purchase a diff car and restore it ..
thanks for any help you can give me .
