Matthew foote
Hey guys.
New to the forum and this is my 1st post. Having issues with my father in laws 2000 Ducato 2.8 non turbo.
He brought it to me not running. No compression on 2 cylinders. I’ve pulled engine out replaced 2 pistons. Done all piston rings and valve stem seals. While doing this had issues getting parts. The machine shop that done the head said it was actually a 2.5 non turbo. I’ve used this machine shop for year and have very good trust in them Got all correct parts put engine back together. Then comes the next problem. While fitting the new timing belt (after getting the right one) no timing mark on outer crank pulley as auto data states. On inner pulley the dot that is meant to be at 6 o clock is more at 7/8 when timing pin is in gearbox. Also the fuel pump doesn’t seem to be pumping fuel to injectors. Are the pumps known for failing ?
