I was wondering if anyone knows this. I have a 2015 Fiat 500 Dualogic.
The user manual is not clear on this and short of a vague hint, it doesn't say what the Dualogic gearbox will do when the car is stopped in traffic with the engine running, e.g. at a red light.
I assume that it will keep the 1st gear engaged and the clutch disengaged ("pedal pressed") for as long as the vehicle is stopped.
If that is the case, then I also assume that if in that situation I move the gear lever into 'N' position, it will put the gearbox in neutral and will release the clutch.
Are my assumptions correct?
Would you recommend doing it (shifting to N) at long stops (to reduce the wear on the clutch bearing)?
Thank you.
Thank you.
