Technical Droan!!
Technical Droan!!
Dan2407
i have had an annoying Droan for the past year..(was expecting something to give up)
The droan seems to be coming from the back and gets louder with speed...you can feel the virbation thought the car 60+..suspected a wheel bearing but there is no play at all
switched wheels with front no change..
I have a new rear wheel bearing expecting to feel play on one side but with no play not sure which one to change if any..
any suggestions? ran the car clutch dipped no accelerator and no chage in noise
Binding caliper if you have rear disks? Hole in exhaust? To test if wheel bearing, does it get louder depending which way your turning? Or go for a long drive down motorway, as little breaking as poss, then pull over n see which side is hotter
