- Joined
- Dec 10, 2007
- Messages
- 257
- Points
- 87
At the start of Part 4 you show the engine/gearbox support. I have bought one of these in readiness for doing my clutch and dmf. I can see how to support the bar with the ends on the edges of the wings but how did you support the engine? I had expected to find a loop through which to put the chain for the support beam! My beam has two hooks and chains like the Draper - do you use only the one on the N/S?
Also I was told at the local Fiat Stealer that you dont need to fully remove the gearbox but only to remove the N/S driveshaft and then swing the gearbox out of the way on a trolley jack with the O/S driveshaft still attached. Anyone know if this is easier?
