My 08 1.3MJ is becoming increasingly difficult to drive, when cold it isn't too bad but once heated up it requires a huge amount of force to get into 1st or 2nd gear. Reverse also does not engage correctly once warm and you get the long crunch as it goes in.
The slave cylinder has been replaced but this has not helped. One garage suggested a new clutch which has been quoted at £425 all in. Obviously I do not want to spend that much money if it isn't going to fix it. Is there anything else that should be checked first?
