Delocking
Delocking
arseofbox
Principality Retained :)
Midlands
Right..was going to delock my Cinq tonight, fallen at the first hurdle!;)
Took the bootlock assy off, it appears that the bodywork metal around the lock barrel is raised in comparison to the rest of the panel.
I want this part flushed...not sticking out!
Logically, I will need to cut this bit out....any ideas on how I should do it?
Tom (AofB)
GrpN Catback Exhaust system on...rattles like f**k, but very nice!!!
ah...wise man suggest angle grinding.
Insufficient space to get a grinder in there...hacksaw methinks
Tom (AofB)
you could try 2 bits of thick steel with a hole in the middle, put one on each side, put a bolt through the whole, do the bolt up and squash the hole flat.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
just remembered sealey do a tool for lock hole repair, this may do the job its £8.95+vat. model no. vs800
there web site www.sealey.co.uk
just had a look at a cinq boot i don't understand why you can't use an angle grinder, unless you mean the sticky out bit is on the inside! then it wont matter.
