Thunderbug
Established member
Does the parking lights use the same bulb as the Daylight Running Bulbs.
These are the ones I bought for DRL's mate, no errors and look the part.
Thank you for the info, they look great, but they are not LED.
I agree, if it is not possible to have error free LED, it will be my choice.I understand that, but there a better option than having errors on the dash constantly.
I've done some research and found out a set of cambus free T20 W21W 7440 LED's with built in resistors works:
I've ordered a set of these, keep you updated:
Like Lloyderzz I ordered the MTEC 380 W21W Super White Xenon Effect Bulbs 7440 “Pair” from hids-direct on eBay.
The ones they sent are NOT the same as those in their eBay picture - they have a black plastic extension on them which pushes the bulb and therefore the filament further into the reflector. So the filament is not at the focus of the reflector and the result is hopeless!
The original fit W21W bulbs are glass-only wedges but are nearly yellow by comparison! ATM I'm running one of each (!); one of the MTEC ones supplied by hids-direct failed after only 4 days use ... b*st*rds.
Can't find an LED replacement that's CANBUS compatible, yet!
Keep us informed please!
