Yep. I'm very confused about it. Won't let me upload videos for it.P0115 error
by any chance ?
fairly common normally due to a faulty thermostatYep. I'm very confused about it. Won't let me upload videos for it.
Oh and my sensor is next to the thermostat to the side of the engine under the air filterpetrol cars have two type of temperature sensor depending on the year, one on the thermostat housing, later cars and 100hp
original was at the back of the block
which have you got
I'm pretty sure this has happened once or twice few weeks back pre starter issues. So I think it's unrelated. Only Because.. Either after a few minutes. Or when I pulled my little OBD thing out... They all went back to normal.
If you changed the whole housing then then it will be fixed as the thermostat is inside !Oh and my sensor is next to the thermostat to the side of the engine under the air filter
Just at work at minute. So can't do photos. I do have a multi meter yeahdo you have a multi-meter ?
good we should be able to sort thisJust at work at minute. So can't do photos. I do have a multi meter yeah
Yeah. I put it down to a dodgy earth. I've recently changed the one under the battery...good we should be able to sort this
you read the engine code earlier, if your scan tool can read live data. See what the coolant temperature reads
if it reading correct the ECU, CTS, wiring, power and earths are correct in this part of the circuit. Be a Good chunk eliminated
do I understand correctly, the gauges were intermittent before changing the parts ?
Looks a bit rough if I'm honestgood we should be able to sort this
