Technical Connect Nav+ GPS/GSM antenna
Bulgaria
Hi to all,
I'm sorry if this is already discussed,but i can't find anything.
So,I bought Connect Nav+ second hand and installed it in my 1.2 Stilo.
I used additional +12v to pin 4; time delay relay and firmware 9.8 update and everything is OK.Till now I used the unit only for radio,cd-mp3 player and trip info,but I already want to use its gps-gsm functions and I want to ask is it necessary to use all this parts:
-electric cable 46760222
-electric cable 51730980
-support 51732347
-antenna 46772567
which are quite expensive,or I can use other combinated gps/gsm antenna from ebay like this:
http://cgi.ebay.com/GPS-GSM-Combined-Antenna-Fiat-Stilo-Connect-Nav-plug-/230522794542?pt=LH_DefaultDomain_0&hash=item35ac3ab22e
Do you think that its technical specifications are suitable for the Unit and everything will work normally?I find another one cheaper version,but it is with other kind of connectors:
http://cgi.ebay.com/GPS-GSM-Combine...296?pt=LH_DefaultDomain_0&hash=item19bf5b2688 , but can I use this,maybe with some adapters?
Please give me an advice about the microphone.Can I use any other,because the price of the original is too big :)
Sorry, I don' know what the technical specification should be. The one in your first eBay link is listed for the Connect Nav+ so it should be the correct specification. You could compare the specifications of both aerials.
Just looked at one of my spare CN+s. You could cut the GT5 connectors off the back of the CN+ and the aerial leads of the cheaper aerial in your second eBay link. You would need to replace them with some other two pin connectors.
Does somebody know where must i connect microphone to my Nav+ and is it possible to take one from Lancia Ypsilon or any other?
I'll be thankful to read your answers and help !
1: Antenna GPS;
2: Antenna GSM;
3: Antenna Rádio;
4: microphone;
5: power supply;
6: speakers;
7: cd changer;
The Lancia Ypsilon microphone (Part Number 735346218) mentioned in the Connect Nav+ fitting guide is no longer available as a seperate part. I suspect a small microphone from an electronics shop would work but you may have to experiment with a few to get one that's suitable.
The microphone connects to pins 9 + 18 of connector D in the diagram below.
There is already a wire placed from the light under the front window to your CPU, when you look ahead a little bit to the right above you you see 2 round buttums push them carfully and the cap is loosen behind it there is a small black connection for your mic, make a connection with your mic and it,s done.................... Then you need the cable/wire from your CPU to your CN+. Now it,s be done and you can use it. Simpel. If it isn,t look and ePER above and you find the right wire/cable
