Christopher31
Hi I'm looking for some advice on what kind of cold air intake system to get for my 2014 fiat panda 1.2
The OEM one pretty much all aftermarket systems do little more then make more noise and any even reduce power a littleHi I'm looking for some advice on what kind of cold air intake system to get for my 2014 fiat panda 1.2
I was told a cold air intake filter is better than just the cone filter I have on the car just now.The OEM one pretty much all aftermarket systems do little more then make more noise and any even reduce power a little
You were advise correctly but I would qualify this by saying it also depends on where your cone filter is taking air from.I was told a cold air intake filter is better than just the cone filter I have on the car just now.
If you are looking for a simple bolt on power increase for a 1.2, I might be wrong but I dont think its possibleHi I'm looking for some advice on what kind of cold air intake system to get for my 2014 fiat panda 1.2
Exactly.The OEM air intake has more than enough surface area to do the job. Compare the throttle body diameter to the air intake diameter. Gas flow for a given pressure increases 16 times when the pipe diameter is doubled.
All Pandas have a cold air intake from the front grille adjacent to the headlight.
I would definitely just replace it with the standard trunking.Hi I'm looking for some advice on what kind of cold air intake system to get for my 2014 fiat panda 1.2
VW were notorious for this with their TDI engines. The 110 was fitted to higher spec cars for considerably more money. But the 90 would chip to 110 and the 110 would go to 140. The 140 could go to 175, but frankly 140 bhp was all the front wheel drive could handle.Occasionally a manufacturer will sell the same car but at two different power outputs. Again it doesn't take long for people to realise. Take the same minis with two different maps. Within weeks people were offering a remap service.
