Technical Clutch pedal not working after clutch replacement.
As suggested by Koalar, I backed the bolts about 2.5mm from the flywheel and there is some clutch pedal travel but I guess I will find out if enough to operate the clutch when the car is assembled again. Also who knows what those bolts are torqued to now🫤
  • signal-2023-05-27-18-20-31-717.mp4
    33.5 MB
Here are some pictures of the flywheel.
Clutch kits and the original.
At first I thought it was the difference in the spring diaphragm that was the problem.
Trans mech clutch kit.
About 6mm gap between pressure plate and flywheel without being bolted, just resting on it.
Nope I think you miss understood me
A very bad idea
Valeo clutch kit.
About 5mm gap between pressure plate and flywheel without being bolted, just resting on it.
Ridex clutch kit.
About 4mm gap between pressure plate and flywheel without being bolted, just resting on it.
Original fiat AP clutch kit.
Shown with transmech and Ridex friction plates. Valeo friction plate does not fit with the AP pressure plate.
All the same measurement from where touching release fork to where touch pressure plate fingers?
View attachment 424222View attachment 424223
Your flywheel has a groove down the drive surface?
Mine bottom image
Yours looks flat all the way probably because your car runs a 200mm friction plate
Mine runs a 180mm, so I guess it has bedded itself in
Did all the release bearing you got with the kits look identical?
The transmech looks a bit different the others are pretty much the same. When I measured them with the calipers they are all the same size.
How can the drive plate sit flat
The flywheel is worn lower at different points
It's a bit more than bedding in looking at the photos, but I am not there
The photo of mine is the wear at 100K miles
The photo of mine is the wear at 100K milesView attachment 424245View attachment 424246
The friction plate sits completely flat on on the flywheel, the marks you highlighted are very superficial. I actually took the flywheel to a machining shop as it was a bit glassed and the guy there told me to save the money, took a bit of emery cloth and right in front of me started running the glassing off of it. Gave the emery cloth to take home as well 😄
So now my question is, is the step the reason the pressure plate doesn't sit flat?
A 4mm gap under pressure plate is about what I had on 100HP and diesel. Tightening the screws pulls in down and slightly reduces the spring fingers angle. Make 100% sure the dowels are correctly located. They will cause the plate to sit high and/or unevenly if they don't locate properly.
I repeat it is not correct
the original posters has already posted a picture of the fingers disappearing when the pressure plate is tightened
I can not emphasise enough that until this is sorted it a waste of time lifting the gearbox in and out
It has to be one or more, flywheel, drive plate or pressure plate, either wrong part or damaged part. Which is what we are trying to sort,
Here a copy of the OP photo
Saying everything is normal is not perticulary helpful
Hi Dave,
the dowels have not been removed, also without the friction plate the pressure plate sits flat against the flywheel.
My car is a 1.2 Dynamic with a petrol engine, year 2004.
Thank you for the suggestion.
You need to put a dial test indicator on it
I don't have the fiat spec but normally it's less than 0.004" it looks like it's going to be more than that to me.
What ever is skimmed off the matting surface has to so be removed from the bolt face also
Too much run out and you end up burning out the new clutch and/or judder
I don't think it's the only problem.
Right let's start at the begining
The original clutch was working and slave didnt break until you changed the clutch
If you put the original drive plate and pressure plate back the fingers still bend flat
The only thing that's been altered is the flywheel has been off and put back
Try removing the flywheel and try without the centre bolts and ring
Be easer to see what's happening on the bench Anyhow
