Multiwagpla
- Joined
- Jun 7, 2017
- Messages
- 6
- Points
- 3
Hi all,
After initial problems with a broken clutch cable plastic pedal attachment I broke my third clutch cable (again the plastic attachment) this week. After lubricating the clutch fork intensively without results, my attention shifted to the clutch cable itself. I have now used WD40 to spray (soak) inside the cable housing at the pedal side, which gave a smooth clutch immediately. Later I will use penetrating oil to lubricate the cable properly. Conclusion: keep the clutch cable lubricated properly, otherwise you could get a very heavy clutch and break either the cable or the plastic pedal attachment.
For anyone who has troubles with multiplas with the mechanical clutch cable (not hydraulic).
Regards,
Multiwagpla
Regards,
Multiwagpla
