MikeyD
Have you checked the hook end of the clutch cable?
how do i get to the hook end/where does it hook into ? i can only see as far as it goes to the bulkhead area.
You shouldn't need to operate the clutch to get the car into gear without the engine turning.
Don't force it, but some will go in, if the gearbag is OK.
Have a look in the engine bay. If the clutch lever is in the rearward position, its definately clutch related. You could try and lever the lever forward again, but it will just pull through again when used.
This should help. The hooked bit of the cable is inside the passenger compartment, under the horrible little servo cover.
From memory, the "other end" is all accessible with the car on a stand on the passenger side and the wheel removed.
The lever is attached to the release bearing arm and is all accessible from the top. No need to crawl underneath.
is it poss that the lever has come away ? (do i access this through the panel in the passenger footwell?)
fiat here doing the cable for £17.47, nippin along to get one later (they only have 1 in stock, would have got 2)
