Have you checked the two pole temp sender, sounds very likely that its failed.
Cheers
What's that buddy?
Cheers
I think they are wrong.
Put your multimeter on the temperature sender in the manifold. My guess is that its reading the wrong temp, therefore sending the wrong amount of fuel.
Cheers
You said you bought the car with this fault and it had a non standard air filter.
Maybe the previous owner after fitting the air filter, then adjusted the fuel pressure regulator to increase flow?
What is an EVAP system?Hi Any chance your injector itself is faulty, considering your issue with the o-ring.
Just a thought. Not too familiar with these models, but does it have an EVAP system?
John.
Hi John, thank you for your reply, actually very informative. But my car is from 96 mate. I don't it have that. I think that exists for emissions and my car is OBD fiat, early ECU with simple coding.Hi,
Here's a link to the information regarding EVAP system, and what it does.
http://www.aa1car.com/library/evap_system.htm
I'm not too sure if your vehicle has this system or not.
I drive a 1.2 Panda 2007 which has this system.
On the Panda, the location is behind the rear drivers side wheel.
Its attatched to the bulk head, a black covered box, which when removed
you'll see black and blue pipes connecting to cannisters, and going in various
directions.
John.
Haynes manual claims Cinqs have it. Haven't bumped into mine though
https://drive.google.com/open?id=0B_KBSf9fX1c4X1Q0VXp0QzFER0U
Have sent you a pm. Have you seen it?Behind the front bumper.
That's exactly what I found with my '00 SPI Seicento. split pipe to manifold vacuum sensor.Had something like this with an spi classic mini today would run and missfire and would be running stupidly rich to the point you could smell the fuel coming out the back
After some close inspection I found the vacume pipe split to the map sensor causing all the problems so check the vacume pipe leading to the map sensor and worst case replace the map sensor
