Technical Check Power Steering
Gloucestershire
2012 X250 2.3 130 MultiJet Iveco engine. 69K miles.
I have had the ‘CHECK POWER STEERING’ warning and red power steering warning light not turning off a few times, after starting.
I have checked the fluid reservoir and it's at maximum level, the light goes off when I turn the engine off/on again, but may intermittently come back on.
I assume the warning light is related to fluid level? However, are there any electrical connections I need to check? Is there a float mechanism in the reservoir? I’ve checked the fluid level and it is good.
Any thoughts or suggestions please?
Hope this helps clarify how the system works. I’m not personally familiar with those engines so can’t help much.
Excellent. I will have a good read of that. Many thanks
