shrewman New member Joined Feb 14, 2007 Messages 4 Points 2 Feb 19, 2007 #1 Could someone please confirm that seicento sporting 2002 reg has a vertical cat box on it? Thanks..............
J333EVO Patron member Parked in the garage Joined Oct 7, 2004 Messages 5,151 Points 965 Location Towcester, Northants Feb 19, 2007 #2 If you mean is the CAT part of the manifold so that it sits behind the rad, then most probably as the Sei Abarth 51 plate I have access to has a CAT like this rather than under the floor.
R randomizered ' Parked in the garage Written a guide Joined Feb 16, 2005 Messages 5,983 Points 988 Feb 19, 2007 #3 Indeedy, all MPI have the CAT in the manifold and two lambda as well, one either side of the CAT. It makes it a bit of a pig to work on and, adds cost to a failed CAT. I can't see the point unless it helps emissions? Kristian
J333EVO Patron member Parked in the garage Joined Oct 7, 2004 Messages 5,151 Points 965 Location Towcester, Northants Feb 19, 2007 #4 The closer the CAT is to the engine the quicker it heats up, the quicker it works at reducing emissions.
OP OP shrewman New member Joined Feb 14, 2007 Messages 4 Points 2 Feb 20, 2007 #5 Thanks for you help.
levemircento Get a wriggle on! Parked in the garage Written 10+ guides Joined Dec 10, 2006 Messages 2,372 Points 743 Location wilmslow, cheshire Feb 21, 2007 #6 this will be the fella, kindly taken from Bosal's online catalogue IMO, its the most sensible place for the cat to be, heats up quicker and out of the way of large puddles and damage from grounding.
