RobertM
Hello everyone welcome to the next installment of 'Man tries to drive 53 year old car thousands of miles and has to troubleshoot things a lot'. Here is my current predicament. I swapped our carb out with a brand new Webber 26, without realizing that we had a 28 on the car already, so we're a little down on power but I can't complain too much about that because the car is running great.... for about 150 miles. Then we get a constant missfire with the car under load and it won't idle. So we limp it to the nearest auto parts store and I spend the next 6 hours in the parking lot taking everything apart and putting it all back together with new parts. I replaced the fuel pump, the plugs (and pretty much everything else in the ignition system was replaced within the past 500 miles at this point) I try a new coil, which ironically was bad out of the box. Finally when I'm about to give up I pull the new carb apart and take come carb cleaner and blow it through all the jets to see if that does anything for me. Sure enough I put it back together and the thing is running great, there was actually a bit of dirt inside of the chamber where the float lives inside of the carb so it actually made sense. I then get back to driving the car, and we end up covering a good 500 or 600 miles with a couple minor hiccups along the way but nothing really of note. Then out of nowhere the miss comes back, so I take the carb off and clean it again, put it back on and if anything it's gotten worse. So we hop in and try to drive it a couple miles hoping that whatever was giving us our issue might clear it's way out, but no luck there. So we stop again, I clean the carb again, reinstall it and now it's running even worse, it wont idle and it's backfiring when I try to give it some revs at idle, but it smells like it's just dumping buckets of fuel into the engine and it's hard to describe but it sounds like it's drowning the engine when I rev it, which we experience the last few times I've cleaned the carb.
All this is to say, towing the car from where we're at will be comically expensive and logistically challenging, it's something that I'm obviously willing to do as I've signed up for this... but I still need to get the car fixed whenever I get home so there's no since in not trying to figure it out where I am now, I will be here for around a week.
My plan is to get a rebuild kit for the webber 28 that we still have and go through it and make sure everything is good. and assuming that we get it working on the car again then I can pull apart the 26 as far as I possibly can and clean the crap out of everything and keep it in the car as a backup. I also plan on getting the smallest micron inline filter that I can (to put next to the tank, not next to the engine) and I'm probably going to buy a new tank for it unless I can find someone to clean the tank that's currently in it for a reasonable price and reasonably quickly.
Does anyone have any suggestions as to why the carb seems to keep sticking open and is dumping fuel into the engine, or if anyone has experienced anything like this themselves? I'll also note I've gone through and checked the ignition system and when I pull the plugs and rest them on the exhaust manifold for a ground I get a great spark on both of them consistently so I am 99.999% confident that we do not have any ignition systems issues... currently.
