The code that i'm getting is p0340 - camshaft position sensor "A" circuit.
Is the cam sensor the one that is near the crank sensor? If so i disconnected this and started the engine and it ran the same.I'm thinking maybe I've got the cam set up wrong from when I rotated it.
This is what i did,
I rotated the crank and noted that pistons 2 and 3 were going up. I then rotated the cam so that the slots on both cams were lined up and checked which valves were opening, to check that pistons wouldnt hit the valves, but now thinking about it they may not be hiting but maybe not on the right stroke.Could this be the problem? Would the engine even run?
