I suggest the notch on the flywheel, which lines up with the window in the bellhousing (above the clutch). There are actually several lines in the window - you want the leftmost one (0 degrees).
Cam pulley lines up with notch in cylinder head as you have found, a little below the 9'o'clock mark.
-Alex
