Liquid Knight II
Established member
- Joined
- Sep 6, 2017
- Messages
- 735
- Points
- 171
Last year I did a kind of "Cheap Car Challenge" as part of the charity track day club my friend Frank Hall organised.
https://www.facebook.com/Franks-Charity-Track-Day-Club-FCTDC-428361030599756/?hc_ref=ARQNFuemBHrVL8Z77j-ORrhJaVlbzHjmM6m7EILZs90U7WJd3UcRnRuUXYnRJmARQ
I took my £230 eBay Bravo HLX and with some Toyo T1R tyres, brake pads and Coupe Bangle Grinder wheels I posted a time of 1:41.3
https://www.flickr.com/photos/frankhall/32816206533/
Had an Abarth in June setting a 1:34.1
Went a bit bonkers in September and got my best lap time down from 1:41.3 to 1:24.8
That's enough about that. If you would like to know more my HLX thread is in the Bravo section of the forum.
Instead of a cheap car challenge I'm doing a "Built vs Bought" instead. Even though at £250 my Fiat Cinquecento Sporting is a bit of a bargain. This is the build car the bought will be along sometime soon-ish and is destined to be a worthy successor to my mighty Bravo.
Why so cheap?
Well she had a sticky brake issue. At first I thought it was the piston getting stuck, but it looks almost brand new. Then I thought it could be the line or knackered master cylinder.
I took the pads out and pressed the pedal to get the piston out as far as possible to inspect the sides and sure enough it was brand new but would not under any method go back.
My only resort was to crack the bleed nipple and push the piston back into the caliper allowing the fluid to flow out that way.
All of a sudden a blob of white stuff (probably grease from where the new piston had been fitted) pustulated out of the nipple like one of those whitehead popping YouTube clips. It gathered into a clump in the bleed line and the piston was slow to retract. I blew the bleed line gear of the obstruction, reassembled the brakes and they now work perfectly.
The grease floating around inside the caliper must have been acting like a one way valve and it was a fluke I cleared it.
Plans are t-jet or N/A 1368cc 16V conversion, brakes, suspension, lightening and all within half the book price of the "Bought" car.
But that's a long way off as yet due to the Winter Equinox celebrations and other stuff and indeed things that are bound to get in the way. :devil:
Why so cheap?
