P
Paul
My 1.2 Bravo (2001, non-ABS) has failed it's MOT due to the rear bearing being worn. I've been told conflicting stories on how it needs to be replaced. I've been told by Fiat that I need to replace the whole rear suspension arm as the bearing cannot be replaced on it's own. The rear arm is very expensive at £167 from Shop 4 Parts.
At the same time I've been told that I can replace just the bearing from a mechanic. I've found a bearing kit on Shop 4 Parts, will this fit? If so, how difficult is it? Is there a guide?
Thanks!
Thanks!
