Hi all, could anyone tell me the Ratios for 1st Gear and the Final Drive Ratio for the box on a 2001 1242 16v Bravo ?
I have fitted the engine from this into a Sei (using a Sei sporting 'box) and find that I'm hitting the rev limiter slightly earlier than I would like.
If there is a difference between ratios on either 1st gear or final drive between either 'box then i would prefer to go with the 'box that will give me a 'longer' 1st.
Any info appreciated.
MODs. I posted the same question on the Sei section also just in case some there has the same engine swap might be able to help.
