All,
I want to remove the clutch/brake pedals from the pedal assembly (1958 N) to replace the cracked plastic bushings and clean up the housing and paint the pedals. I removed the roll pin through the clutch pedal and then the clutch pedal, shaft, and outer plastic bushings with no problem. But for the brake pedal in the center, it appears to be retained by the two sleeves that the bushings/shaft fit into. Do I have to press those sleeves out of the housing in order to remove the brake pedal and replace the bushings? I'm a bit nervous of damaging the sleeves and/or housing. Anyone done this? Any thoughts/advice appreciated.
